Water pump
benboy17
Just bought a water pump for my 93 Bronco. Seeing i have never done this before how hard is it to change? Are there any tips you guys have for changing it? How long should it take me?
Thanks
Ben
bidibronco
Norfolk Va
Just the water pump? Not to hard, is it the 351 or 302? Either way it's not to hard, You'll have to pull the fan and shroud together to keep from messing anything up. Also be carefull taking out the bolts, sometimes they like to get cruddy and brake. You'll also have to take off the driver side accesories since they go on on of the bolts. Two or three of the bolts can only get gotten with a DEEP socket or wrench. A hand full of the bolts also go threw the timing cover and into the block. All in all it's not hard, two hours if you take your time and do it right. Maybe less?
benboy17
I have the 302
yeah, keep track of where each bolt goes, since some are different length. Might want to refernce a Haynes or Chilton's manual for more info, JSM84
bidibronco
Norfolk Va
Also, if you have a digital camera or camera phone you may want to take some pictures before you get started incase you forget something you can refer back to them.
benboy17
ok got the pump off but rung two bolts off. got one out with wd40 any tips how to get the last one off. It just rung the head off so i can get vise grips on it but it does not budge. Any tips would be great!!!!! Let me tell you there was some nasty junk in there!!!!
BroncoJoe19
Soak them with PB Blaster and post pictures.
You may need to use an "Easy-Out" bolt extractor if the head is broke off.
bidibronco
Norfolk Va
If it's one of the longer bolts that go to the block you can get a pully puller and pull off your balancer and take off the whole timing cover. Once you do that hit it with a good penetraiting lubricant and you can get vice grips on it. If it's one of the top three, drill it out and hila coil (is that right?) the thing. I've done that on mine. Any other bolts just look at it carfully and if you can drill it out and put the hila coil in it that's great or if you can pull the timing cover off that's great to or you can try an easy out. I prefer the one's that are square over the ones that look like a goofy reverse drillbit but that's personal preferance there.
benboy17
Got them out thanks guys!!!!! That PB Blaster is great!!!! Lots of PB and alot of hitting with a hammer and vise grips and out it finally came!!!
