Warn premium hubs
Nilsande
If it has only the 5 ***** holding the hub on all you you should need is the hub kit, The spindle nut kit is for the 3 ***** automatic hubs. I just bought as set of warn premiums from Advanced Auto for $89.99, and the spindle nut kit to go along with it, for about $40 I think. I had the 3 ***** auto hubs, so I need the conversion kit to complete the swap. Make sure you a 1/2" torque wrench that will go up over 150lbs. The outer spindlenut needs to be torqued between 160FtLbs-205FtLbs. My swap went smooth the hardest part was trying to get the lock ring out with a modified wire coat hanger for a pic.
scrubtopdoc
