grande_guerre
grande mondiale
I need help. My 84 351W that i just put in has a vacuum leak, i think... it idles like crap but acceleration is fine. Decel is crappy too. any help would be awesome. it's carberated too. thx.
Ok then you hava a way to go. First off, you need to get a vacuum schematic for your engine. When you changed your engine, did you replace it with the same size? Was it a 302 for 302 or what? We need to get to a good starting point.The thing is, i'm terrible at vacuum and when i swapped the motor, i just hooked the carb up correctly with vacuum, but everything else, i just hoses to and went from memory of the old engine. I also stopped every port i didn't use. There are no check valves anymore, i didn't know where they went. I've sprayed wd-40 around some of the spots i think it is and it doesn't run as rough at idle anymore. so i think i've narrowed it down to a vacuum restrictor that's on the firewall, the tree on the manifold or the connections at the carb. But they all seem tight... Thanks for the help guys.p.s. timing is good and i do not have an egr.
19142[/snapback]
