It's me again. Still mostly a lurker til I need an answer. A little background to the Q. A couple of months ago I was real busy at work & dropped my '69 off at a local service station / shop that I deal with to change the rear U-joints for me, since I didn't have time. As it turned out, it was really just the ball & socket in the CV joint worn out. We talked about a couple of options, being converting it to a solid shaft, which I understand is pretty common, or get a new, late style (Spicer) shaft. Mine's got the Borg. Well, I could get the repair kit & U-joint for my Borg for just a little less than a whole new Spicer shaft. Meanwhile, the paint shop finally had an opening, so with the rear shaft out & the front shaft locked in, off to the paint shop we go. They got the new shaft, only to find out we need to change the ****** on the transfer case. A little money for a part, mo' money for the labor. OK, back up, let me do my own thinking again. I got the Bronc out of the paint shop a couple of weeks ago & decided to do MY original thought, just get the repair kit, which I did. This evening I didn't have to work late so I was going to put in the rear shaft. Here's the problem. The 'clamp' part of the CV joint & ****** on the transfer case seem too small for the U-joint caps. The caps fit perfectly in the yokes, a perfect, smooth press. I measured the new cups to the old & they are identical. The bolts are about 1" long & are nowhere near long enough now. I had some 1 1/4" bolts in the shop that I can draw the 2 parts up to within about 1/8" - 3/16". The ID of the 2 pieces are definitely smaller than the OD of the cups, but they used to fit together! The only manual I have covers all the Broncos, & none in a lot of detail, but IIRC, says torque to 17 ft/lbs. NO WAY! The front shaft U/CV joint is flush & flat & is supposed to be the same assembly as the rear. Since I didn't take it apart, I don't know if there was a gap there or not & the shop's closed at this hour. I can't imagine it not fitting flush like the front shaft. I really need 1 1/2" bolts to secure it, it looks like & surely I'd need some sort of spacer to transfer the stress loads properly. The rear ******, that uses the 2 U-bolts, went together with a perfect fit. The new parts are also identical in dimensions to the new parts as well. So, Oh Bronco Gurus, what the heck's going on here? Thanks!
