Turn Signal Trouble
swaff
Somewhere in the South
I have a 1996 Bronco XLT. The four way flashers work, but the turn signals will not. When signal is on, bulbs are lit solid. Tried new flasher relay. Any help appreciated.
firelt90bronco
Ask me about my job
northeast
Check the bulbs, double check the relay and trace everything back, it could be a bad circut or ground.
escortwgn
Shaw AFB, Sumter, SC
my 84's doing that. my ignition switch has loose conections. what i do is play with the key while it's in the switch and move it around a bit. not sure if it's wired the same on yours. hope this helps.
Why don't you fix it :blink: ? Sounds like you need a simple switch position adjustment. May bee it is even a little lose. The switch is located on top of the steering column just past where the shaft goes thru the dash.
canueverstfu
Ducktape = ultimate Fixer.
dude i had the same peoblem, exactually the same, you may not belive me but try this, check all the fueses, that was 1 of my problems because the 4 way is different from the 1 way... and if you have a trailer light connector in the back of ur bronco then follow that line and see if it has any split wires, or open ones that are touching the frame that was my reasons why it was doing that, and i hated it... but i never had that problem again. just try :-D
kc.collins21
