TUNNING 89 BRONCO 5.0 TPS SENOR
JIM KLIM
I HAVE A 89 BRONCO WITH A 94 H.O MUSTANG LONG BLOCK WITH A E 303 CAM HOW DO I TUNE IN THE TPS SENOR. I NEED TO KNOW WUT WIRE TO TEST IT FROM.
THANKS
http://home.comcast.net/~miesk5/technical_...d%20for%2093-95
The Mustang 5.0 is shown in da chart; poor quality Image, but best I can find so far.
note; Throttle Position Sensor Service Part Application Charts for car and light truck. The charts also
contain TPS idle voltage ranges. These idle voltage values should be used instead of the values published in the 1993-95 PC/ED
Manuals.
Throttle Position Sensor (TPS) Test in a 92 (loosen the 2 Phillips screws until voltage is less than 1.0 volts @ idle (.97 volts) Source: by Richard C (Bigric, Money Pit) at SuperMotors.net
Use the CHART in da TSB for voltages.
More TPS Links in my site
GL!
seansz28
