ttb hard parts upgrade
markmn123
so ive searched high and low not to mention the search on this forum isnt too good im just looking for anyone that would know how to upgrade the components on the ttb front end i have an 88 bronco so i know its based on the dana 44 i just need it to be able to handle ALOT more power...and if there are upgrades what can it handle
Miss Kitten
alberta canada
are you looking for advice on a full solid axle conversion?
what kind of "power" are you talking about? are you looking at a bigger engine, bigger tires?
You can upgrade to OEM stub shafts from a Dana50 TTB out of a F-250, but it's only a slight improvement IMHO. I ran a fullspool in the stock TTB front on the 84 Bronco before going to the D60 SAS, with minor breakage on one side with 35" tires. You might chekc with JBG, but I don't know of anyone making chromoly axleshafts for the D44 TTB.
M
markmn123
i was hoping to not have to do the solid axle conversion and im not running that big of tires or planning to they are 30 or 32 and i wanna be able to go into 4wd without doing too much damage granted that will be hard cause i am going to have a 525 in it is the solid axle alot of work and expensive?
rostheiceman
florida
well its either a bmw 525 or he means a 428 cobra jet crate with 525hp lets hope its not the bmw
BB33's
Rancho Cucamonga CA
I never heard of a 525 but I have hear of a 528 which is a 460 that has been bored .30 over and has a stroker crank and longer rods.
M
markmn123
its a 460 bored and stroked to a 525 ci. with a completely forged rotating assembly trick flow heads and massflo efi
If you can be more specific as to what you want to do with the Bronco, you might get some more detailed advice. Like are you planning to run the mud drags, drag strip or perhaps a dirt track? In those cases, both the front and rear 1/2-ton axles would need to be strengthened to handle 550-600 HP, or you'll likely be breaking parts on a regular basis. Upgrading to one-ton drivetrain parts and doing a SAS may cost a bit more, but you're still going to spend several hundred $$$ per axle to 'beef' them up. I switched to the F-350 drivetrain on my 84 Bronco primarily for mud drags, with some mods for trail use. JSM84
The kind of horsepower you would get out of that it would be plain silly to keep the half ton susp. ! ton is the way to go
BB33's
Rancho Cucamonga CA
A great 1/2 ton rearend for the Bronco is swapping it for a Ford 9.75. It has the ABS tone ring and VSS and will bolt right up and be only 1 inch wider on each side. The spring plates will need to be moved but thats only 20 bucks to weld at a local ****. shop so no problems there. This axle actually exceeds a semi floating (3/4 ton) Dana 60 for strength. They can be found in many later '01-up F150's there is even a disc brake version.
crazyhorse85
clarksville,tenn
I agree with jsm84 and yardape that kind of power you really need to think 3/4 or 1 ton suspension...1/2 ton won't hold up very long to the abuse...The old saying do it right or don't do it at all...I think you'd be better off and a whole lot happier with the finished product....Good luck and post some pics of the finished truck..... B)
Staff online
seansz28
