Truck wont start
82BRONCO
I went to start my bronco the other day and it made a clicking/grinding noise when i tried to start it. The engine didnt turn over but what I think is the starter solenoid made the sound. I tried to jump the battery but i dont think i let the cables on long enough. When i tried to start it was right after I intalled some offroad lights. Could the battery be dead, bad solenoid, fuses, circuits??? I KNOW NOTHING? Any advice helps. I have been wheeling in like two days!!! Thanks in advance!!!
82 bronco
D44, 9in rear
31inch mudders
Trac Lock-rear
TX_BEAST
waxahachie texas
most likely battery isuggest charging battery and also double check the wiring for the lights you installed. after charge if wiring on lights is correct then should have battery checked with tester.orielly and autozone both should do free battery test.
Ford644
