Why cant you pull the gear off? Its just held on by a small roll pin
yes, as Yard advised or get a loaner tool from most parts places, esp the place where you are buying the parts....
http://www.arizonatools.com/tools/ignition.../detail/THX415/
"Thexton 415 Ford Distributor Gear Installer and Remover. Works on all Ford vehicles with TFI-IV ignition systems 1983 and up. Removes the distributor gear so that the hall effect switch may be serviced - installs gear back on shaft after servicing. High strength steel construction. Tool is designed not to apply any stress to the gear teeth, eliminating damage to both gear and shaft. Replacement distributor gears are not available should they become damaged. The distributor must be replaced as a unit."
As Yard advised, another distributor is the way to go; solves a lot of problems...but to save $$, know how it is...
Some more FYI stuff;
"! ! ! PLEASE READ THE FOLLOWING INSTRUCTIONS CAREFULLY PRIOR TO INSTALLATION ! ! !
OVERVIEW:
The following information covers the installation of a new distributor gear onto an existing distributor. When
replacing the distributor gear, it is important that you choose the appropriate gear for your application. If you have
questions regarding your gear selection, please contact the Ford Racing Tech
