Tread
pwcdoctor
I have High and low spots on my tire tread, its like patterned high, low high low, anyone know what causes this?
TX_BEAST
waxahachie texas
could be worn out shocks or bad alighnment, actually be good idea to check entire front end for worn bushings ball joints steering joints etc.
mbtech2003
cape cod, mass
Let me guess right front tire right....... mine does this even with new ball joints and the alignment is good and nothing is loose besides the steering box :)) never happenes in ford trucks :-"
i'm still trying to find the problem in my truck to see y this is happening.
i'll get back to this if i find the problem :glare:
trashman1980
it is commonly refered toas being chopped it is usually caused from not rotating the tires, i rotate every 5000 miles.
Are the high and low spots in one; the outside edge, center of tire or inside edge?
muddog
Indianapolis, IN
its definitley because its a ford. sorry but fords are ******* tires. my 93 also does the same thing. the twin I-beams are the main root cause. the best thing you can do is rotate more often. about every 4-5 thousand. Ive worked at discount tires for three years now and even the new ford trucks have this problem. just a small price to pay for being the best!
cowboydan
i see lots of tires shredd appart because the owner doesn't bother to check the pressure. if all you ever do is check/maintain pressure, your tires would last alot longer.
scrubtopdoc
