transmission question
mannyjmf
indian trail nc
Hi all, my question is, my bronco is a 1986 with the 300 6cyl and a 3 speed automatic tranny, i would really like to put an AOD in her, my question is what AOD would i use and would it really require any major modifications? thanks
You would want an AOD from an 86-88 Bronco or F-150 4x4. The AOD from a 302, 351W or 300I-6 will bolt up to your 300I-6 and t-case. You'll want to get the t-case to tranny adapter for the AOD, along with the shifter linkage for your t-case. You may have to modify the t-case shifter linkage from an AOD/B-W 13-56 t-case if you have the B-W 13-45 or NP208. The AOD also uses a T.V. cable, which needs to be properly adjusted for the AOD to shift right. You might find some info on the swap in the link to Miesk5 Homepage in the Tech Articles forum, JSM84
