yo D
What Tranny and what year Bronco?
If it's an AOD;
Consider the Lokar Brand;
#89. AOD, Lokar braided stainless steel throttle valve cable kit. Cost $76.00
LOKAR SITE INFO NEXT:
Lokar Throttle Cables and Kickdowns
Call Toll Free 1-877-469-7440 for more information.
Throttle Cables
All Lokar Throttle Cables are available in either stainless steel braided housing or black housing. They are designed with a specially extruded liner for extended life of the cable – not to be confused with ordinary braided brake hose. Cables are equipped with aluminum fittings and aluminum ferrules to eliminate fraying. “U-Cut-to-Fit” outer housing is available in 24" or 36" lengths with a “U-Cut-to-Fit” stainless inner wire. Clevis is designed without cotter pins or set screws. Adapts to factory and aftermarket pedals. Custom lengths available upon request. Cables mount nicely with Lokar’s Stainless Steel Carburetor Bracket and Return Springs (sold separately). Kits complete with installation instructions.
Scroll down for part number listings
Part Numbers
TC-1000HT 24" Stainless Steel Hi-Tech Throttle Cable
TC-1000HT36 36" Stainless Steel Hi-Tech Throttle Cable
TC-1000U 24" Universal Black Throttle Cable
TC-1000U36 36" Universal Black Throttle Cable
TC-1000TP Tuned-Port Stainless Steel Hi-Tech Throttle Cable
TC-1000BLD Blower Drive Stainless Steel Hi-Tech Throttle Cable
TC-1000LS1 LS1 Stainless Steel Hi-Tech Throttle Cable 36" (for Ramjet)
TC-1000EFI EFI Stainless Steel Hi-Tech Throttle Cable
‘94 & ‘95 Ford EFI only*
*For 1986 - 1993 EFI use our TC-1000HT or TC-1000U
TC-1000TPV Vortec Stainless Steel Hi-Tech Throttle Cable 36"
TC-1000MOD Ford MOD 4.6, 5.4 V8 Hi-Tech Throttle Cable
http://www.mypartshop.com
Select;
All Parts
year, etc, then FORD TRUCK
Zip Code
I went thru 1989,,etc,,etc,
then since there is no TV/Detent/Kick-Down listing, I chose Transmiss,Transaxle
then selected A.T. AOD
This will give you a Yard List w/ph #s etc.
GL!
