transmishion
bronco86
[-o< will a manual transmishion off of a 351 windsor fit on a 302?i think it is the same block .
and i need some opinions on what is better manual or automatic
seawalkersee
Outside KCMO
I have to say they both have their advantages. More power to the ground with the manual, More controll of low speed stuff (as long as its not tooo radical of an incline, but then they both ****). But if you wanna do a lot of mud jammin then the clutch can get gooey and then slip. But you dont need a cooler for it either.
brokenbronco666
point pleasent N.J.
i dont like automatic trans'es because say your out on the trail if you loose a quart af automatic tranz fluid your not going any where. your stuck out in the woods
ocalabronco
ocala, Fl
yes, it will bolt right up. but converting from auto to stick is a PITA. and so you know for later on in life, its TRANSMISSION, not transmishion. there is no H
Wihill
