Transfer case shift lever questions
Chuck K.
Trying to convert my son's 87 F/S Bronco from the elec. shift to manual. I have purchased a manual shifter for the 1356 x-fer case but the seller thinks it came off of a C-6. My son's bronco has an AOD will the shifter work. I am also unable to find the shift lever that bolts to the x-fer case itself. One end has an oblong hole that bolts to the x-fer case the other end has a "***" that plugs into a grommet on the shifter lever.. Thanks for any help. Chuck
CHuck, I'm getting the shifter and linkage for the B-W 1356/AOD combo from Jdenninger, and will post a pic when he sends it to me. I was hoping to take a pic or two of the linkage on my 86 Bronco. Even though it is a manual tranny, I think it has a B-W1356 t-case by the side-mounted shift lever.
Was unable to look at that today, as I had to tow her home the last mile. LONG story, but the battery is dead, had a dude hook up a battery charger to it. Instead of charging it fully, he just quick-started it, and ran out of gas on the way to my house. Then it wouldn't stay running for more than 10 seconds using jumper cables. So I just hooked on to it with a chain and dragged it home. I wasn't going to leave the Bronco on the side of the highway overnight!!!
swampthing
you will be able to use the lever you may just have to get it cut and re-welded for proper length
I crawled under the 86 today, and it has a NP208 t-case. The shifter linkage is very similar to the B-W13-56 linkage for the T-18 tranny. I think I posted a pic or two at FSB.
