texan79&96
- Joined
- Nov 29, 2004
- Messages
- 172
- Reaction score
- 0
i just swapped in a 205 from another bronco into a 79 that had a 203. it went together very straightforeward other than drilling one hole in the framerail for the sidemount. i used the bronco 205 to c6 adapter and driveshafts from the other bronco and now the 79 c6 that worked great with the 203 doesnt move the truck. we lost alot of fluid when it was pulled apart but it seems to be full again now. ive tried it in every t case gear to get the truck to move and nothing. everything shifts and feels like normal except it grinds when you try to go back into park with it in any t case gear running. what could cause this?? should i just keep adding fluid until hopefully it moves?
