tranny mating
deuce
Will a 91 302 bolt to my 351w c6 tranny? Also I want to deck out this 302 get as much H.P. as I can ne1 got ne suggestion on wut performance parts I should use!!
thanks
swampthing
yes the 302 will bolt up to the C6....what kind of spending limit do you have for parts and is it EFI or carb
D
deuce
I got about $2000-$3000 spending limit and engine as was EFI but my truck is carb so I'm gonna go carb. Also will my t case bolt to AOD tranny
MOst all ford T cases have the same bolt pattern so you can take one off a 1976 and bolt it right to a 1996 ofcoarse the shifter linkage and supports are a different story but it will mate to the T Case :D /emoticons/[email protected] 2x" width="20" height="20" />
fourbybuilder
Shady Spring Wv
Yes the bell housings will bolt up just make sure you check to make sure you have the right spacing on the fly wheel. I swaped my 302 for a 351w when i bolted the 351 to my aod the fly wheel was spaced to far back causing the torque converter to ride against the pump in the trans . Needless to say the aod lasted about 14 miles befor it lost line pressure and welding the clutches together. So now I run A c6 and all is well
seansz28
