Tranny Help
walkdawg
Jacksonville North Carolina
I just replaced my 302 with a 351 w. I have a AOD tranny and I am haveing trouble getting it to shift. It was working fine with the 302 what could I have messed up and what can I do to fix it?
wrachet
Kansas City Area
I don't know much about transmissions..but obvious causes....
fluid level low?
fluid smell burned?
fluid color?
Colleen
curlygrooms
arkansas
30101[/snapback]
may depend on year models,i put a 95 351 in my 90 bronco,and fried the tranny instanly,in 95 ford went to ectronic shft,this took a tranny that was just enough longer that my 351 pushed the converter into the pump and fried it.the other problem is the cable linkage that runs to the top of the motor beside the throttle linkage.it has an adjustment on it and must be set perfect to make it shift right.strongly suggect you have a good ford type tranny person set it,it's real touchy and must be just right to get it to shift..hope you come out better than i did.once around the block,cost me a new tranny..good luck
