Tranny Fluid
firelt90bronco
Ask me about my job
northeast
I got a 1990 bronco xlt with an automatic transmission, I'm going to change the fluid when I replace the pan gasket. Which type of fluid should I use.
You should use Ford AT-type fluid which is Mercon III. Only replace the amount you drain out.
ocalabronco
ocala, Fl
you're going to replace the filter as well as the gasket, right? you might as well, you're already in there
liftedbill
connecticut
32387[/snapback]
ya jimmy change the filter i may have 1 let me no GIT-R-DONE
Ford644
