Torque convertors
gungho
I need a torque convertor, for an E4OD. Engine is a 5.8L. Does someone have a good one lying around, or know where to get one?
Buying a used one with unknown mileage will be an iffy thing with an E4OD . The overdrive clutch is located in the torque convertor and there is no way to inspect it . I would really recomend buying a new one from ford unless you knew fro sure it was a functional torque convertor . The one in my 95 is worn badly you cant even feel it shift other than watching the tach very slushy . :D /emoticons/[email protected] 2x" width="20" height="20" />
Wihill
