Tire And Wheel Size
76jon
I have a '76 bronco that has not been cut front or back and would like
to know what the largest wheel tire combo that can be used with stock
and/or 2" suspension lift. I currently have 15x8 wheels with P235/75R15
tires and the rear tires rub the fenders.
STLKIKN
Calgary Alberta
Well, you already know that a 235 is too big for your truck...
But if they were on a seven inch wheel, the rears PROBABLY wouldn't rub ( your suspension may be too sagged out)
A 31 10.5 on a 7" wheel with 3.5" of backspace should work with NEW three inch rear springs (not blocks)
A 33 9.5 should work on the seven inch wheel with blocks...
A 33 10.5 may work with new springs and the seven inch wheel.
These are my opinions... they are based on past experiences with EBs
They may not work with your truck (depends on your springs)
Please don't rush out and buy new wheels without doing your lift first..
Remember to test fit wheels/tires before buying!!!
This is one of our past trucks...
A 77 with superlift 3.5" lift, 31 10.5s on 7 inch wheels.
79' Buckin Bronco
