1966 roadster
So I went out and pulled the dizzy cap off and turned the fan by hand "with the engine off" and watched the dizzy move.
it DID NOT move instantly I measured it with a tape, I can rotate the fan blades almost one inch before the dizzy starts to move. I checked the belts to make sure they were not slipping before i took my measurement the belts are good.
Im looking at my book and it looks like a easy process changing the chain out but my book DONT recommend changing out the sprockets??? is there a rule of thumb when changing the timing chain?
WHAT IS A FUEL ECCENTRIC PUMP??????? can this go bad????? should i change it out???
THANKS
THANKS
