Tie Rod Ends Torque Specs
jimbronco91
Great Falls, Montana
I have checked previous posts but I didn't find anything on actual Torque Specs for Tie Rod Ends for 1991 Ford Bronco. I am trying to finish while there is a break in cold weather.
chrlsful
S. Amherst, MA 01002-1827
How much do U weigh?
Tighten dwn the nut a coupla times (hand, then open end - 6 or 8 inches long). When firm hang upper body (simply put some beef into it) on wrench'n ****...not whole body... Make sense. After doing enuff bolts - U to will have tq wrench in ur wrists... Common sense, less Chit ona tool cart, less runs to the bench/tool rack - more drivin time 8^ 0
J
jimbronco91
Thank you that is what I ended up doing & the front end on test drive performed perfectly.
79' Buckin Bronco
