Thermostat replacement
uscdiver
San Diego, CA
Hello all,
Does anyone have any tips and or instructions on replacing the thermostat? THanks for the help!!
diver
Big Country
San Antonio, TX
your best refernce point for the thermostat would be in the hanes manual. once you get to the housing, there should be a bolt on either side of it. take that off and your thermostat should sit in it. take it out, put the new one in with the gasket, don't forget the gasket seal and put the housing back on. that should do it. the only tip i can give you is remove anything in your way. it makes it easier.
Motormouth2025
