Thermactor System
Bronk351
Well my motor is out of my bronco, due to me trying to use it as a submarine. Well anyways, im planning on cleanin her up. I got rid of the EGR a couple of months ago by using the Eliminator from RJM injection, and i made my own blockoff plate. Well with me having no cats, the thermactor system is pretty much useless, i even had one of the hoses undone from the air pump.
So from this point i know i need to plug the back of the heads with some pipe plugs, and copper RTV, but what do i do with the vacuum lines? I know i need to disconnect em but what ones do i disconnect? Anyone ever do this, or have any idea what ones. I wanna make sure i dont take the wrong ones off. Thanks for the help
yo!
I recall you have a 92-96?
Some info for now;
Removal, Belt Diagram, Belt PN & Info in a 91 5.8 Source: by David B
Stainless Steel Thermactor Smog Plugs $15.00 & other egr removal parts
http://rjminjectiontech.com/?p=9
& Ryan's EGR Removal Instructions
notably; "...Disconnect EGR Valve Position sensor (EVP), and inspect the harness connector. Make
sure it
Jimi61
Minden, Nevada
So after reading posts here I have done some mods. Removed smog pump. Short belted. Removed EGR and plumbing. Installed block off plate and eliminator from RJM. Capped vacuum ports. Capped and plugged exhauts holes {RJM plugs}. AirAid throttle body spacer. Next is the exhaust system.
Its is showing a check engine light and I have yet to get the code.
1991 351W SD
yo JIMI
Since I made that reply; Ryan wrote elsewhere,
When performing computer Self-Test after installing this kit it is normal to get code:
33 / 332 EGR valve opening not detected.
The computer is acknowledging that the EGR is permanently closed. This is your desired
result. However if you get the following codes:
31 / 327 - EVP circuit failed below the closed EGR limit of 0.24 volts
32 / 328 - EVP circuit failed below the closed EGR limit of 0.24 volts
34 / 334 - EVP circuit failed above the closed EGR limit of 0.67 volts
35 / 337 - EVP circuit failed above the open EGR limit of 4.81 volts
Code 33/332 is the desired result, if the light still comes on:
Check your connection again; make sure there is no resistance in the harness.
or you'll need the $300-$500 chip. Or just live with the light!
Source: by Ryan M (Fireguy50)
http://96.0.50.30/EGR_eliminator.pdf
trett86bronc
