Deep
Need to change the door crank shaft where it connects at the vacuum control motor. Plastic piece on my 1987 Eddie Bauer Bronco broke off. Actual door is still functioning, however it doors not work properly being it is no longer connected to the vacuum motor and as a result my inside window defrost does not work at optimum. Has anyone done this before and do you have any tips. Any sources on where to get a replacement..tried junk yards, but they are all fragile.
Thanks,
Deep
Thanks,
Deep
