Taillight Differences
derrick36
I have read stuff like that also, then in the description they say this ...
"1987-1996 FORD F150 AND 92-96 BRONCO EURO ALTEZZA TAIL LIGHTS -2PC SET"
21680[/snapback]
I didn't read that far. Are you looking for clear?
derrick36
There is a set of black ones on ebay, was thinking about them
21683[/snapback]
I see which one's you're talking about. Those are pretty nice. I took a look at Broncograveyard.com, and they're listing the same ones for 89-96. If it was me, I'd buy them. I really think they are the same, but of course I'm not 100% sure. Sorry, this didnt help very much.
derrick36
No prob, thanks for giving it a shot !!
21688[/snapback]
Have you tried contacting any off the sellers? It looks like there are a few sets listed, so maybe someone will get back to you in time.
I have a set of clear tails for a 92-96 Bronco for shows and a set of the 88 stock tails that I use the rest of the time on my 84 Bronco. The size, pattern and bolt holes are the same from 80-96 for 3 of the 4 bolts/screws. The one hole that changed from 86 to 87 is from the inside, when you open the tailgate. I just put a rubber plug in that hole for the ****** and the other 3 hold the lens just fine. So, a set of 92-96 tails will fit on an 87-91, and even the 80-86 Bronco/F-150.
BroncoForever
Omaha, NE
87-96 taillights are interchangeable and are the exact same shape. The only difference is on the 87-91 taillights, the lower clear part is as wide as the whole lens were on 92-96 ones, the clear part is smaller with red around it. I personally think 92-96 taillight lenses look alot better than 87-91 lenses. If I had an 87-91 Bronco, I'd replace the taillights with 92-96 ones.
Good point. That's why I swapped out to the 88 lights, since the white part on the 84 lenses is so tiny. The wider clear section on the botttom of the 87-91 style lights makes backing up at night a tad easier!!!
Wihill
