Tailgate Problem
Bronco89XLT
Medford, NY (Long Island)
I swapped tailgates this week, the problem is when I close the new gate it won't latch. I replaced both latches, the handle, the linkages and the center mechanism that all the linkages are attatched to.
What I have found, is if I pull on the linkages to simulate it closing / latching, it closes and latches better than my new car's doors.
The parts I used were not new, but they were each the best I had out of 3 tailgates. I tried different combinations of parts with no positive results.
THANKS!!
It sounds like the latches work OK by them selves but fail to lock around the strikers. Have you tried adjusting the strikers. They have a place for a Torx wrench and when loosened you cna change their position.
Bronco89XLT
That is my next thing to try, I have to get some new Torx wrenches. Some idiot stole mine out of the back of my truck one night at work!! They left the $300 amp anf the $500 sub and took a $50 set of tools!!! MORONS!!!!!
mbtech2003
cape cod, mass
27018[/snapback]
could of been worse :ph34r: /emoticons/[email protected] 2x" width="20" height="20" />
Koopa132
Scotia, NY
If you're just adjusting the striker you can just use a pair of pliers on the outside of it and don't necessarily need a torx wrench.
fordtruckman
sometimes you can use an allen wrench in a torx head but not always. and you have to watch for slippage of the allen wrench if if slips don't try any more just go ahead and get a torx bit.
79brnco
