Remove the decorative piece under the steering conumn
Remove the shroud on the steering wheel
Remove three screws on the dash cove above the instruments
Remove the two knobs on the left (a strait pick inserted behind them to release the ****)
Remove the instrument bezel
Disconnect the shifter threaad that is attached to the column on the left side
Remove the 6 mounting screws on the instrument panel
Disconnect the speedometer cable (squeez and pull the connector)
Unplug the connnector that attaches to the connector on the rear right side side of the panel (squeeze and pull out the connector)
Remove the instrument panel
Remove the screws holding the clear plastic face on the panel
Remove the 4 cap nuts that hold the tach in place
Reverse to reinstall
I may have left something out, if so you will find it
