Stroker kits?
Bigone96
Vandenberg Air Force Base
I am looking for an affordable stroker kit for a 351 windsor can you tell me where to get one? Would like it to be some where between 400 and 460 cubic inches. Thanks
Barta
seawalkersee
Outside KCMO
The most common one is the 408-410 kit with racers. You need to make sure when you get a stroker kit that A: The wrist pin is not in the lower ring, and B: the rod ratio is going to be good enough that you wont burn out the rings in a year. This is common because race cars usually rebuild more then once a year. It is not good for daily driving. I would stick with something under 400 like the 370-380 kit if it were me.
Chris
Wihill
