Striker Bushings
Bradt
Georgia
I need to get the bushings replaced on my tailgate strikers. I got the ones done for my doors free from the scrapyard, but didn't get the tailgate ones. I have some pvc pipe that may work on it, but don't know if it's too brittle. Anyone tried using it before? What other items have you used? I just can't see paying 3 bucks for a one inch piece of plastic.
I have 2 strikers for the door jambs if anyone wants them. They have the strikers and the metal brackets. The brackets are painted black. One of the strikers is a little stripped out where you put in the star bit to ***** it in, but there should still be enough there to use it. All I needed was the bushings off them.
brad
CACTUS JACK
West Texas
In the sprinkler section at Home Depot, they have some black plastic tubing called crazy pipe or whacky pipe. It is semi-rigid and doesn't last as long as factory, but works pretty well. I cut this to length and then split in a spiral along length. This helps it stay on the striker better.
Wihill
