Strange Starting Problem - '88 Bronco
bronco_kid
I'm a beginner so bare with me. My bronco won't start. The key will turn the ignition but no sounds, crank, spin, nothing. I've installed a new starter, starter cable, solenoid, and battery. Still nothing. The truck powers up, all of the lights and electrical stuff works. Although, I did notice that with the key turned in the start position, I cannot shift out of park. I fould this out while getting it towed, nor can I apply the parking brake or release the brake.
Any help greatly appreciated.
BigNasty
SquirrelBait
NC
Sounds like a mechanical issue in the column, possibly the switch itself..
I haven't messed with too many columns, so I can't help pinpoint it.. :) /emoticons/[email protected] 2x" width="20" height="20" />
shaun94
bronco commander
hooksett N.H.
I had the same porblem with one my trucks. to find out if it is the ignition switch just jump the starter, If the truck turns over then you know you're switch is bad.
Wliebhard
Albuquerque, NM
I'd have to agree. I know the key is supposed to disengage the steering wheel lockout when it's turned, so the lock cylinder is probably broken.
The key itself and the lock cylinder for that matter do not directly make the electrical connections to start the vehicle. The ignition key lock cylinder pushes and pulls a rod (which is on top of my 1985 bronc's column). This rod is attatched to a box about the size of a matchbox and is approximately 18-20" down the steering column. The rod moves a pad with electical contact points across a set of hot points and connections, actuating the required task (start, run, accessory) This box has a bunch of large gauge wires (I think 10-12g.) That are yellow, black, ect. running into and out of it. I would strongly advise not taking this box apart, as there are several pieces in it that are spring loaded!! I made that mistake and fixed it 3 1/2 hours later :blink:
If your electrical system is good, and depressing the brake pedal won't let you put the old gal in gear, then the problem almost HAS to be mechanical in nature. Get a Chilton's AND Hayne's repair manual (good cross reference, but some errors), as there is a specific way to replace the inition lock cylinder. Good luck. B)
Wliebhard
Albuquerque, NM
One more thought. Bear with me, because my Bronc is an'85. When you depress the brake to shift it, the brake pedal makes a connection and allows the shift lever to move. I'm not sure how this system works, but you may want to check that switch as well.
Bronco chuck
Guest
My 88 you dont have to depress the brake pedal to shift still not new enough for that I would try to wire the starter right to the batt and see if it starts
Bradt
Georgia
When you get to the last stage before starting does the fan for the heat and air come on? Does the steering wheel unlock?
Since it's an automatic and you know the shifting doesn't work right, maybe that's the culprit. Most cars, when the key is turned and they're not all the way in park, will do the same thing. Lights and electrics work, but no turnover. You say you can get it into park, but are you sure that it is really registering as being in park?
Brad
tagto138
Maine
if you have a chilton's or a haynes manual look up neutral safety switch. this switch is designed to only allow the vehecle to start in park or neutral. i will take a look at my manual to to see where it is. also look at all the fuses and inspect all the fusible links to the solenoid. if you know how to bypass a solenoid to start it i would check that next. but if you don't. don't try it.
EB Bronco
Check if the Bronco is actually in park or neutral. I replaced the battery, removed the starter and had it checked at autozone. I couldn't figure it out, but the Bronco started right up when I jumped the starter wire. The problem was the truck was in drive and just about ran me over. That's how I found out that my shift cable had broke. The Bronco said park on the column, but was actually in Drive.
Roger
MAVRICK513
I had a similar problem. Truck did everything but start. I could start it by jumping across the terminals on the starter solenoid with a screwdriver but not with the key. In my case it tuned out to be a bad neutral safety switch.
12039[/snapback]
Do you feel any resistance like spring loading when turning the key into the start position. If not you should, there is a spring on the actual switch which returns the key to the run position when you let go of it. From what you are saying I would suspect it is the push rod from the key to the switch which is mounted on top of the column under the dash area. If this rod brakes, your key does absolutely nothing. It is also required to unlock the shifter, a tab on the top of it lockes the shifter in park.
Take the shroud off the steering column and see if the rod moves when you turn the key. Usually you have to remove the trim piece on the dash under the steering column in order to get the column shroud off. Be carefull not to dammage the small line that causes the shift indicator to move. There is NO mechanical relationship between the brake and the shifter.
guilhermeknob
