I have an '86 Bronco with a 302 EFI. Nine times out of ten, it starts immediately with no throttle, but every now and then it will just crank. If I give it half throttle, after about 15 seconds it will start to stumble, and slowly improve over a few seconds, until it is running fine. It never quits after it is started. I assumed that the fuel pump was not pressurizing the rail before the key was turned to start. When it is in this mood I have tried turning the key to run and leaving it on for a few seconds, before trying to start it, with no change. I replaced the fuel pump relay but it did not help. Has anyone solved a similar problem? Any suggestions would be appreciated.
I see from my manual that there is an EEC power relay. Anyone know where it is on this truck? It also shows in the pump circuit the electronic control assembly. Is that the computer or the ignition module? I assume the inertia switch is good or it would not start at all.
This basic EFI stores codes that are read with a test light. Can anyone point me to instructions for hooking the light up and interpreting the codes if any? My manuals do not cover the topic. Thanks for any help you can give.
