strange noise
89EB302
Bridgeville, Delaware
For the past few days I have been trailering a very small boat, and cranking the steering pretty hard. I just noticed that I now have a rubbing/grinding noise under the passenger floor when I turn the wheels (mostly at stop or low speed). I am thinking bushings, but I am not sure.
If the noise is when you steer hard right, you may be rubbing your front right tire on the radius arm. If so, you should be able to see the mark on the radius arm if you look under the right front wheel well. Solution, don't do that :) /emoticons/[email protected] 2x" width="20" height="20" /> .
Wihill
