Starting Problems
Fisherleep
I replaced my hacked up 69 wire harness with a good used 75 wire harness because the old harness the previous owner had cut it all up and converted it to an electronic ignition also dropping in a 79 302 it ran if you wiggled the wires just right so I got the used one. My problem is that when I turn the key nothing happens, there is a new starter motor relay, ignition switch, ignition key and cylinder all wire are connected correctly that I know of checked many times, good ground. I have a manual on the floor and the 75 harness is from an automatic does any one know if that could be the problem because I don't have a neutral safety switch hooked up to anything? Is that why it does not want to start because it thinks it
Post only in one place. I replied in the other forum before I noticed you had duplicate posts. This actually is the right place to post technical questions :D /emoticons/[email protected] 2x" width="20" height="20" /> .
Welcome to the Zone
79' Buckin Bronco
