nine milly has an 89 Bronco ...
We have asked nine milly to post the Year, engine, etc. in past.
some thAngs to try;
"...turne the key onto crank(nothing happened), reach low on the column, just below the dash, and shove pick tool into the column and pull down. That thing not only rolled over but it started...SO IN CONCLUSION REACH UNDER YOUR DASH AND PULL DOWN ON THAT COLUMN SWITCH ACTUATOR ROD (with the key on) AND SHE'LL LIKELY START RIGHT UP. the switches die but they can also "walk" up the column and and get so loose the rod coming down from the key will not actuate the column switch(it's also a sign the $11 switch is about to die)..."
Source: by Sixlitre
No Start Troubleshooting;
"...First thing to check is wiring.
Between the large posts of your starter relay should be a smaller post with a wire attached. This is the wire from your ignition switch through the Park/Neutral Safety Switch (NSS)/Manual Lever Position Sensor (MLPS), Or clutch safety switch on a manual trans, or NSS/MLPS with an AOD/E4OD, to the starter relay and the on to the starter solenoid (if equipped) and starter. Check this wire for cracks, open insulation, or anything that could possibly cause an open circuit.
Next, check your upper ignition actuator. Find the ignition rod (on top of the column, running from the steering wheel down to the ignition switch at the base of the column) and make sure it's moving back and forth when you turn the key, through all positions. If it is, your upper actuator is probably not the problem.
Lastly, check your ignition switch (again, at the base of the column). Manually push the switch back and forth through the different positions. Push it all the way forward (or down) and see if it will engage the starter. If it does, then your ignition rod is probably bent, which can be remedied quite easily.
& If it's an auto, try starting in neutral or while pulling up on the lever while it's in park. If that works, look to the Park/NSS/MLPS. If it's a stick, check the clutch switch.
Check to see if da relay is tight to inner fender with no corrosion because the relay's body is ground path via inner fender). If it does turns over jumped to the small terminal, then you'll be looking for something in the small circuit that includes the ignition switch & the park/neutral safety switch (NSS/MLPS) Or clutch safety switch. There should be 12v running from the ignition switch, thru the NSS/MLPS, to the small terminal on the starter relay. Disconnect the small wire to the starter relay (So it doesn't start by surprise, I'd pull the coil wire too). With someone holding the key in the start position, you should be able to read 12v between any point on that small circuit & ground. When you find where you lose 12v, then you'll know where the issue is...";
MIESK5 EDIT; changed a few terms;
MIESK5 NOTE; from Ford EVTM; The Control Module (PCM) runs the pump{s} for one second when it receives an ignition- on signal. It also runs the pumps as long as it receives a PIP signal from the Hall-effect devices, it continues pump operation even after the key is released from START. If the PIP signals fall below 120RPM, the control module cuts off the signal to the fuel pump relay. The pump will also run when the terminals of the fuel pump test connector are jumped. the Control module signals the pump when it receives a CRANK signal, and when the Control module gets PIP signals that the engine is running. the pump does not run if the PIP indicates the engine is not running even with ignition ON {except for that first one second}. Hopefully it could be a dead cell in da battery.
by BigUgly88EB and ElKabong (Ken, El Kabong)
