Starting problem ignition or coil?
oregonred
I recently got my bronco running after sitting for 4 years. It has a 429 and started right up about a week ago. I turned it over about 20 times today and when I released the key to the ON position it started. From then on it will not fire in the start position, but everytime I release the key it attempts to fire. It is still turning over strong in the start position. Any ideas?
Can a moderator delete this post, I posted in the wrong forum. It is a 78 bronco.
bidibronco
Norfolk Va
Wait, I'm confused... Are you saying it will turn over and the engine will spin but the engine will not stay started? If it's trying to start and will run a bit, try the alternator. Since you have nothing about your truck other than it's a Bronco with a 429 that's about as far as I can go. Try to get some more stats like year, tranny, fuel injected or carbed all that good stuff and it makes it easier to help you...
seansz28
