Had the same issue starter tested fine had shop to warranty it anyways replaced solenoid and both ground cables worked perfectly fine since. Almost certainly was the grounds due to heat soak but started solenoids are cheap replace it while your there just to play it safe89 Bronco 351---The starter is new--but when cold it cranks good but the problem is when the engine is hot, driving it around, the starter labors-? Is it the ground wire--solenoid or ?
Thanks---when you say both ground cables---do you mean battery ground cable and solenoid ground cable ? looks like the battery ground has two other wires out of it -? Don't know what I'm looking at I guess.Had the same issue starter tested fine had shop to warranty it anyways replaced solenoid and both ground cables worked perfectly fine since. Almost certainly was the grounds due to heat soak but started solenoids are cheap replace it while your there just to play it safe
Thanks,--I see the ground connecter has two wires on it on the negative connecter--do they come that way or do I have to splice wires-? I'll have to find out what they do---maybe another ground or anti lock brakes--??Yo captsb890,
I believe @Bdezeeuw meant it for the battery grounds to engine block and frame. Those two are known to corrode there and at battery + terminal under the connector.
etc
by El Kabong @
"Cheesy clamp on end. Do not use for a long term repair. Only to get you home when nothing else is available. If you have one of these, suspect it before anything else" El Kabong @ Common Replies to FAQs
Yo captsb890,Thanks,--I see the ground connecter has two wires on it on the negative connecter--do they come that way or do I have to splice wires-? I'll have to find out what they do---maybe another ground or anti lock brakes--??
