squeak in front axle
bew8484
Indiana
Alright guys I need some help. I have a pretty bad sqeak in front end somewhere. It sqeaks whenever I am moving. Forward or backward or whichever way it doesn't seem to matter. So first I went to change the brakes. Went and bought the rotors and pads and everything. When I got the tires off the rotors didn't even so much as need turned. The pads looked brand new. So now I'm confused. I am getting ready to upgrade to warn premiums. Is there anything I can check while I've got everything apart? If not, what's next? Maybe bearings and alxe seals? Thanx in advance.
Brad
fbrown3
West Virginia
Do you hear the squeeking when you turned the rotor by hand? might be able to narrow it down if you got your head up in there while turning it.
I doubt that the new hubs will correct the noise, but like fbrown3 said take some time to find out what is actually causing the squeek. It could be a bearing starting to go or just your brake pad but you don't want it to fail when on the road :(( .
