Spindle Hub Socket?
waterdog
Trying to put some new warner hubs in a '83. I can't get them all the way in on the drivers side. Friend of mine side i need to buy a spindle hub socket and tighten it up. Is their such a thing, if so what size and where can i get one. I just did a search and read about the axle moveing back. I'm going to try that first. Any help would be appreciated.
waterdog
94_bronc
st.paul mn
are you talkin about gettin the snap ring on cause the axle will slide back just enough to cover the slot for it
W
waterdog
'94- i can't get the hub pushed in far enough to get the snap ring on. The passenger side went on with out a problem. Thanks for the help, any other suggestions.
STLKIKN
Calgary Alberta
waterdog,
Reach through the steering knuckle, push the axle u-joint out towards the hub.
You should now be able to see the snap ring groove.
stinger
East TN
waterdog
waterdog there is a spindle hub socket but it is for your wheel bearings. like said above try pushing the axle outward from the back side to get the clip on the axle
