Speedometer question
leos74
The old speedometer in my 74 bronco looks like it went thru heck and back(not remotely working) i'd like to put after market gauges on the dash without spending an arm and a leg speedometer,oil,temp,battery any ideas on that.
Where do you find a used cluster?  what about any gauges or gauges sets that are aftermarket
25002[/snapback]
Toms Br. Parts, ...JBG, I'm sure, has them. >
The prob. with aft. mkt gages, is there's so little room on the dash. (That round cluster has everything you need...) BUT, B/4 replacing, be sure all the senders & wiring hook-ups are up to par. AND, your "speedo cable" may be the culprit.
HTH,
Bob
79' Buckin Bronco
