specifications
Broncoboy07
Bronco Obsession
Burnsville, MN
Under the topic "first bronco" I got the engine specifications from seabronc and it was about the horsepower and torque. I needed that, but I also need to know stuff like height, width, length, wheelbase, etc. Thanks again seabronc for those specifications. I also would like to know if there is any modifications I need to make to a 94 Bronco with the 5.8 V8 and it has spent all it's life in Minnesota. Thanks everybody.
cowboydan
go buy a haynes manual for 15bucks and you will have specs out the wazzzoooo
ocalabronco
ocala, Fl
things to look out for. IIRC, they use salt on the roads in Minnesota when it snows. inspect the lips of fenders, and inside the fenderwells for rust. closely inspect the paint around said areas to make sure they didnt just paint over it. look at the base of the tailgate also. i would say take it for a test drive, but i dont know your proximity to it
Broncoboy07
Bronco Obsession
Burnsville, MN
I find the tailgate and fender lips rust first. The tailgate has some rust, but I think I can sand it off and use some touch up paint.
scrubtopdoc
