Smoking rich
Spike
Aruba
Hello is me again. My bronco is smoking black and everytime i start it , it shoot out black liguid. So i dont know what exacly it is , maybe it have something to do with fuel pressure?
ford bronco 5.0 v8 1989
Tnks,
2NDTOUR89
Southern Oregon
Check your codes first but probably the TPS or O2 sensor. Mine did a similar thing but also surged really bad to the point that it would stall. Put in a new TPS and O2 and it runs like a top.
Good luck.
S
Spike
Aruba
My did the same it would stall to. I found the Os but i dont know where the TPS is? Can you show me a pic are something?
2NDTOUR89
Southern Oregon
TPS is located on the bottom of the throttle body. Find your throttle linkage then go to the opposite side of the throttle body and you will find it. You will have to remove the throttle body to replace it.
S
Spike
Aruba
thnks for the info guys . I think with information like this the mecanics will be out off work soon!!! lol . Hey i saw by Xris pics that his intake and TB for crud build-up why does that happend? my intake filter is black ass **** from that thing. i cant' smell the oil wehn i take out the intake filter
I believe you have a PCV breather filter in there... change that too; a dirty/clogged air filter can cause Rough idle, black smoke from tailpipeas long as it's not oil soaked, just change the filters
If oil soaked or aroma in future, blow-by gases pressurize the crankcase, the pressure would force the oil up the PCV breather hose & contaminate the PCV
breather filter & air filter.
over time & mileage the throttle plates & body, & TPS, etc. will build up carbon on them, this carbon can cause all kinds of driveability issues
S
Spike
Aruba
well like what i saw the oil soak in the intake filter. so i have to buy a breahter filter. so now i know why the TPS is not working propely. well thnks very much for the info men . By the way last time the car was ideling bad we have clean the IAC it was black from oil , so now i know that the pvc breather can't causes alot off problem in the future.
ok, but change the air filter and breather as you wrote....check for blow-by; I entered a reply about blow-by in another post here yesterday.
Also, Rich Mixture or Blow-By caused by Dirty Intake Air Temp (IAT), pic on a 92 351W Source: by Richard C
"If your engine runs too rich and you have blowby, the IATS will get dirty like this. It will NOT be able to correctly determine the temperature of the air charge"
It's a 2 wire sensor mounted in the air cleaner housing
blow-by and a fix that Dustin did;
http://www.misterfixit.com/blow-by.htm
Here is a good article about carbon buld-up;
Carbon Deposits; As a vehicle approaches higher mileage, you can generally expect intake valve deposits (IVDs) and injector deposits. Their onset can vary widely, depending on driving conditions. Engine operating temperature, intake manifold gas speed (rpm) and hot soak cycles are some of the critical operating parameters affecting these deposits. To lubricate an intake valve, tiny amounts of oil have to run down the valve stem. Over time, this oil is deposited and heated on the intake side of the valve, forming a carbon cone. This has multiple effects on the intake event, The carbon changes the aerodynamics of the intake event-namely causing higher gas speed and a change in the direction of intake and swirl, which affects the combustion process. The IVDs also act like a sponge, creating a delay in fuel control. This delay not only creates a temporary enleanment on acceleration but also causes a temporary enrichment on deceleration. When the throttle is closed, the intake manifold vacuum goes high, pulling the fuel out of the carbon sponge. This affects fuel control, potentially affecting catalytic converter diagnostics under OBD II.
Source: by Mark W, in Motor, Dec 2002
S
Spike
Aruba
Hey im back . Wel the car is running better then before no more blow by. but i didn' both nt yet i just clean the intake , PCV breather filter and the throttle body with carborator cleaner. this week im buying the new intake etc. But i wanted to ask if i throw oil flush off oil treament wich one is better ? can't that help for cleaning the durty oil in the cranckcase are just wait for in the future to pressurize the cranckcase?
Spike, save your $ for the new parts. Or do a SEA FOAM treatment someday; if it running good now, let it be free...
Sea Foam
S
Spike
Aruba
Wel miesk i did throw seafoam already in. But does the seafoam damage the spark plugs? And i im busy saving up for new parts as you wrote. I will let you know when i get some parts.
OK Spike..good chOb man!
it is recommended that you check/change the plugs after the process...I pulled just 2 to check....on old 78; one was crudded..so, did a complete check & replace; you can just do a quickie pull of #5...since it's running ok, I wouldn't waste too much time on checking all, esp.# 4, 6, etc.
btw, what type of intake are you buying?
S
Spike
Aruba
Well 2 weeks ago i bought the original one. but im planning to buy the K&N filter.
seansz28
