ok,
Yes, a vac gauge will help; any type is good..better yet; one that can be perm. mounted on or under dash
Vacuum Gauge Tester Instructions
Source: by tradervar.com
Also, Sorry, I got you mixed up with another person elsewhere who has a DTC 332 too.
Check thru my broncolinks.com site under Emissions for EVP, EGR, etc. tests. I know
Ryan M (fireguy50) has a lot of test info in his site
Now I don't recall if I gave you da following yet; can't seem to go back thru this entire thread in Reply Mode.. my laptop sux:
DTC 332 - Insufficient EGR flow detected. Atop the EGR valve there is a sensor called the EVP (EGR Valve Position) sensor. It detects movement of the pintle iside the EGR valve. You can apply vacuum to the vacuum barb on the EGR valve and observe through the holes in the casting whether the valve is moving or not. It may just be dirty which requires some careful scrubbing and NO SOLVENTS. Otherwise, if the EGR valve is functioning and moving when vacuum is applied, the EVP sensor is suspect and the electrical connections to it should be checked first. (Computer needs to know the EGR valve position for emissions control).
Source: by greystreak92
DTC 332 & Possible Causes; "...
EGR Valve Insufficient EGR Flow; EGR valve sticking closed EGR valve diaphragm leaks; EVR solenoid sticking closed; Loss of vacuum to or from EVR Open in
EVR or driver circuits; Leak or restriction in PFE/DPFE signal hoses..."
Don't know if your yr has the Pressure Feedback EGR Sensor, (PFE) or a Differential Pressure Feedback EGR Sensor, (DPFE); if it is a CALIF vehicle, it does...
Ford has on-line Emission/etc Label that is = to the label on rad support in your Bronco; Ck all those vac sources/users for tiny leaks again
DTC, Repeated in 86-94; Troubleshooting, bucking or trailer hitching condition during shifting for 86-94
Source: by Ford via niehoff.com
"...SYMPTOM: Repeated PFE-DPFE Sensor Code
APPLICATION: FORD, All With PFE-DPFE Sensor (86-94)
Ford vehicles equipped with a Pressure Feedback EGR Sensor, (PFE) or a Differential Pressure Feedback EGR Sensor, (DPFE) may experience repeated occurrence of false EGR system codes and possible incorrect replacement of components due to limitations of the factory diagnostic procedures. While the Ford "H" manual does include reference to the EGR valve as a possible source of an EGR PFE Sensor code it does not address valves that "Hang" momentarily.
Our testing has found that contaminant build-up in the area of the EGR pintle shaft, or pintle seat may cause the valves on these applications to be slow in opening when the PCM commands additional vacuum be applied to the valve. Sensing that insufficient EGR is occurring the PCM commands for more vacuum to the EGR valve. When the valve does pop open the combination of valve inertia and vacuum build-up cause the valve to over travel. This creates the sensed excessive EGR condition that triggers the false code.
Drivers complaints usually include a bucking or trailer hitching condition during shifting or initial off-idle acceleration as part of the driveability complaint, which can be especially noticeable on manual transmission equipped vehicles. EGR valve replacement is the recommended service.
A similar false code may also occur if the metering orifice located in the intake below the EGR valve and DPFE sensor is restricted. This type of problem will not create a trailer hitching condition but loss of fuel economy will be noted. Cleaning the orifice will correct this condition.
Always check to make sure that the ground straps are in place and complete connections are made..."
See Link for depictions
[url="Idle Air Bypass (IAB) Overview & Testing; "First let me say this little thing has many names. But they all talk about the same item under the hood. Here all the names I
