Smells bad, is it?
jonnybravo101
WASHINGTON state
Whuss up Bronc Bro's ? 1995 xlt 5.0 302
Quick problem, hopefully quick fix. After engine runs for around thirty minutes, smells like anifreeze, slight steam coming from passenger side defrost vents, and window on that side gets all foggy. I've read previous posts and my symptoms are different, but still thinking its my heater core. Any similiar symptoms or confirmations? Got a few hours of free time today and when I go out for Beer, I might as well pickup a heater core. Thanks All-Even if your just reading :)>-
J
jonnybravo101
WASHINGTON state
Thanks again Bully Bob. New heater core installed, and problem solved. I was driving and decided to cool off with A/C, nothing but HOT air blew out . Retraced my install steps and found the cable connected to the top of the plastic heater core housing loose. Apparently, I knocked it off of the white plastic lever under dash. Put it in its proper place and good to go. This cable comes from the temperature dial on the dash. Just a little warning for all those removing plastic heater core housing in the future.
Motormouth2025
