Coffey the shocks on the front are different lenght from the other. On a single shock front endGreat info and will do, thanks!
Will do, thank you sir.Yo Coffee,
We used Bilstein shocks in our former 78 with 4 inch lift.
I forget part #, so see Bilstein site @ https://www.bilstein.com/us/en/
I tank it has an issue so wait until tomorrow if you can't search there.
Here is some 78 Bronco info for you:
1978 Bronco Dealer Brochure via member Indybronco
MANY 78 Parts Break-Out Diagrams by member Indybronco (Lula Mae) @ pictures, videos, and sounds | SuperMotors.net
1978 Bronco Emission Component Location Diagrams via 78brncoxlt
PARTIAL DEMO 1978 Ford Bronco & Truck Wiring Diagrams by Ford via member BroncMom @ Demo78 wiring diagram.pdf
1979 Bronco/F Series Electrical & Vacuum Troubleshooting Manual via member Ziggy; similar to 78.
1979 Wiring Schematics, Connector Pin-outs, etc by member Ranger429 @ 79 wiring schematics
Similar to 78
Bubba's M-Block Ford V8 Workshop by Dave Resch @ Bubba's M-Block Ford V8 Workshop
78 351M/400 Engine Exhaust Emission Control Information Decal & Timing by member grovermyson @ Timing - Do I need to do anything ?
Partial Chilton Manual for 1978, 1979, 1980, 1981 Bronco. Scanned by broncocity.com @ Bronco City
Ford Shop Manual Diagrams: 1978-1979 Full Size Shop Manuals, partial @ Technical Diagrams Archives
My Tablet takes too long to download, so try the first in this list as long as you have Adobe Acrobat 9 installed. Let me know if the downloads are worth the effort.
Includes:
Wiring Manuals & Diagrams Download PDF
This complete manual for the 1972-1979 Ford Bronco Includes Rear Lights Diagram
Motor Manuals & Diagrams Download PDF
This complete manual for the 1972-1979 Ford Bronco Includes Air Cleaner Diagram
Chassis Manuals & Diagrams Download PDF
This complete manual for the 1972-1979 Ford Bronco Includes '78 Brakes Diagram, Gas Tank Setup Diagram
Body Manuals & Diagrams Download PDF This complete manual for the 1972-1979 Ford Bronco Includes; Upper Body Diagram, Front Clip Diagram, heater Ducts Diagram, Tailgate Diagram, Console Diagram, Front Clip Diagram, Grill Setup Diagram, Heater Controls Diagram, Interior Trip Diagram, Rear Sheetmetal Diagram, Tilt wheel Diagram, Tire Rack.
Check your measurements against the site before you order them from anywhere. These are for the dual front end shocks 4” lift for bilsteins
24-186513 for for in front of
so I just looked up the both front end part numbers and they’re both the same lengths? Is this for a bronco. Radius are side should be shorter?Check your measurements against the site before you order them from anywhere. These are for the dual front end shocks 4” lift for bilsteins
24-186513 for for in front of spring
24-065283 for attached to radius arm
24-185530 If you don’t have the rear end figured out yet
I went with those front end as they were indicated for 6” lift as well, they are not for 6” lift only 4. I had to do some measuring and phone calls to sort mine. Hope that helps.
Not sure who my last reply went to. The ones you listed for the front are both the same lengths? Radius arm side should be shorter. Is this for a bronco?Check your measurements against the site before you order them from anywhere. These are for the dual front end shocks 4” lift for bilsteins
Well Coffey on both of my 78 .The FRONT shocks--are NOT the same length. I even asked the parts people about it and they said they WERE different lengths. If they ARE the same length. You can tell it quick.Not sure who my last reply went to. The ones you listed for the front are both the same lengths? Radius arm side should be shorter. Is this for a bronco?
I know it sounds odd,but it is.Well Coffey on both of my 78 .The FRONT shocks--are NOT the same length. I even asked the parts people about it and they said they WERE different lengths. If they ARE the same length. You can tell it quick.
I’ll give it a shot. Thanks for the info.Well Coffey on both of my 78 .The FRONT shocks--are NOT the same length. I even asked the parts people about it and they said they WERE different lengths. If they ARE the same length. You can tell it quick.
Have you or anyone thought about going to air shocks all the way around? I been thinking about it. After I get my gas problem fixed.I’ll give it a shot. Thanks for the info.
It is for the bronco yes, and yes they are the same length, the radius mounting sits higher than the post sticking out of the axle. This is why I said measure before ordering, these numbers are what they list for the 4” lift dual shock set up.Not sure who my last reply went to. The ones you listed for the front are both the same lengths? Radius arm side should be shorter. Is this for a bronco?
I’d do it for sure. For now just need to get the new build done quick and easy, nothing easy.Have you or anyone thought about going to air shocks all the way around? I been thinking about it. After I get my gas problem fixed.
The way I fixed a set. You don,t have any lines to fool with.I’d do it for sure. For now just need to get the new build done quick and easy, nothing easy.
Cost, and do you have any pics? How’s the ride? What the likely hood of popping one?The way I fixed a set. You don,t have any lines to fool with.
Well what we done was. Took a set of air shocks, tire vales(2) Burn the rubber off of them. Clean them good. Take them and gauge the size in a drill bit gauge. Take the drill bit of the same size and drill into the air inlet on the shock. After its drilled. Take the tube vale and put it in the air shock and braze around it. Put the valve stem in it. Put on the truck and add air. My friend ran it for a good while before he traded it off and said they rode real good and never gave him any trouble.Cost, and do you have any pics? How’s the ride? What the likely hood of popping one?
I,m planning on making a set for the front of mine. I have air shocks on both of them. They,ll raise one about 2 inches. A friend gave me a 3 inch body bushing set the other day. Think I might put them under it.Mine needs replaced anyways and figured I,d use them.Well what we done was. Took a set of air shocks, tire vales(2) Burn the rubber off of them. Clean them good. Take them and gauge the size in a drill bit gauge. Take the drill bit of the same size and drill into the air inlet on the shock. After its drilled. Take the tube vale and put it in the air shock and braze around it. Put the valve stem in it. Put on the truck and add air. My friend ran it for a good while before he traded it off and said they rode real good and never gave him any trouble.
Now when you drill into the shock air inlet. I think all you have to drill is about a 1/2-3/4. Keep the torch pointed way --go side ways. Also check both ends of the shocks. To make sure they are for what you are gonna put them on. I,m gonna make a set for mine before long. I have about 4 different sets of air shocks. Ford,GM AND Dodge. I,m a muliti guy--I like any old car or truck. Long as it DOES have points in it.Well what we done was. Took a set of air shocks, tire vales(2) Burn the rubber off of them. Clean them good. Take them and gauge the size in a drill bit gauge. Take the drill bit of the same size and drill into the air inlet on the shock. After its drilled. Take the tube vale and put it in the air shock and braze around it. Put the valve stem in it. Put on the truck and add air. My friend ran it for a good while before he traded it off and said they rode real good and never gave him any trouble.
cost of a set of air shocks ($50-$60) most old tire valve cores are free .Anyone who sales tires .Will give you the old used one. I,d say the cost of everything would be the shocks. Most tools to do the job.A person already have them and a little time.Cost, and do you have any pics? How’s the ride? What the likely hood of popping one?
