Shifting Problems on my '94
jaydoubleyou
I'm having some problems with my shifter. Everytime I start the Bronco, I can't get it out of park for a couple of minutes. I usually have to jiggle it around, press the brake real hard, or just wait for awhile. Then it works fine. Sometimes when I start it up, it works perfectly right away. Also, every so often I can't even turn the key without moving the shifter around.
Anyways, I think that the problem is either the connections to the shifter are bad or that I need an entirely new one. Does anyone know where I can get the parts or about how much they'd cost? Or if this is even the problem? Any help would be appreciated.
-jaydoubleyou
BRONCFOOT
Newberry, SC
-jaydoubleyou
32271[/snapback]
Is yout truck 91 or older or 92 up?
bidibronco
Norfolk Va
I'm not sure if this matters, but if I don't make sure that my shifter is in park, it doesn't like to do anything. Wont hardly let me have my key and when I put the key back in it doesn't like to shift. Just my 2 cents
eholt80
