Shift Motor
Burns
Royersford, PA
I ordered a new shift motor from JBG because mine's shot, and when I went to replace it, I noticed that the one on my transfer case has the plug plus 3 wires that offshoot to another part of the transfer case. I don't want to cut them for fear it'll cause another problem, but the new one has only wires to a plug.
Anyone else have this problem and have a solution, short of a 4x4 mechanic?
Thanks
Call the Bronco Graveyard. They have some pretty knowledgable people that I'm sure can help you. their numbers are
(248) 437-5060
(248) 486-1760
happens w/replacement motors; as Fred adbvised call JBG after reading this info below so you know what to confirm with the tech person.....
Transfer Case, Borg Warner 1356 Electric Shift Motor Connector, Missing Pins, Ford
Source: by CARDONE
Burns
Royersford, PA
Meisk5, thank you SO much! That's exactly what I needed. Popped out the wires from the old motor and popped them into the new motor (all the wires were the same color from old to new, which REALLY helped keep the guesswork out from frying the motor) locked my manual hubs, and hit a close dirt road. Kicked it into 4x4, and she rocked it.
Again, thanks. >
Meisk5, thank you SO much! That's exactly what I needed. Popped out the wires from the old motor and popped them into the new motor (all the wires were the same color from old to new, which REALLY helped keep the guesswork out from frying the motor) locked my manual hubs, and hit a close dirt road. Kicked it into 4x4, and she rocked it.Again, thanks. >
We can always count on Miesk5 when running out of ideas :D/ .
79brnco
