Shift Indicator Adjustment
djwendt
Albuquerque, NM
I read a post earlier but I am sure my problem is in the adjustment. Often when I put my bronco in park it does not engage the transmission, I have to move the shifter to the left again and play with it a little and then it will engage. There is alot of play in the shift indicator to the point your not sure your in the right gear. I feel it is a adjustment problem and if anyone knows how or has had this problem I would appreciate any feedback.
1995 Bronco XLT
5.8L
I had that problem, and adjusted the shift linkage below the cab on the C6 tranny on my 84. Try looking in the Tech Articles forum for the link to Miek5's Homepage, and go to the transmission section. Your 95 Bronco has the E4OD auto tranny most likely, JSM84
here's a link to "Shift Cable Adjustment" on the E4OD:
http://www.supermotors.net/vehicles/registry/media/434182
D
djwendt
Albuquerque, NM
Chapin1736
