Shaking in the front end
B-Cack
Anybody have any experience trying to isolate a shake in their Bronco? I noticed mine started to shake like a blind ****** at a weenie roast the other day. It is funny because it seems ok from 0-30, but 35-45 there is a pretty bad vibration in the front end. I am not sure what to do first, check wheel bearings etc? Any comments are welcome, Thanks
Sometimes tire balance will do that. You may have thrown a wheel weight. Hit any *** holes or big bumps lately?
fbrown3
West Virginia
:-B If it shakes only at the 35-45 mph you might check you tie rods , I have found if it only vibrates at a certian speed this is usually the culprit. If it is continuos then I would look towards the ball joints, bushings, bearings and such. (my 2 cents worth.) :huh:
B-Cack
B-Cack
Thanks, my initial eval was that it was the tires, but it only seems to do it when you press on the gas, leads me to believe it ins't the tires. Scheisse!
Ford644
