67 Bronco Jay
1967 Bronco how do the seat belts go onto the bolts with the spacers? Is there a connerter between the hot wire and the wire from the map light? I had the Bronco painted the wires were left disconnected the wire comming from the map light has a bigger end that will not fit in the feed wire so it must have had some kine of connector there. If so where can I get one?
